I’m not sure how this is set up, the VC website only mentions Voice Control although you mentioned that it was possible, I need manual/PLEG control Richard can you point me in the right direction on how to achieve this?
I already have VC set up but no google home.
You can setup for Voice control … and just not do any voice control!
OK, Thanks for the update.
Next problem…
I’m unable to learn RF codes.
Did it work with the other Plugin ? Can you learn the RF with the Mobil App ?
I do not have an RF device to test with. Is there something cheap and available to test with ?
Yes, was able to add in through e-Control as a User Defined device.
Perhaps one needs a method of Importing the data from the backup?
I will look into it …
