I am using GE Concord Plugin “GE Concord Alarm Panels” via USB Serial adapter to connect to my Concord 4 panel. VeraPlus controller can control all the functionalities like Arming / Disarming using scenes within the Vera UI7.
But in Vera Concierge service, I don’t see the Alarm partition under “Security (Alarm/Lock)” tab. Can you please help me how I can get my Alarm partition added to Vera Concierge so that I can use Google Home to Arm / Disarm my home?
I also have the concord 4. Mine does not show up in VC. I believe this is by design at the moment. The devices connected to the panel do appear.
For me, I use scenes to control the panel. These do work in VC.
Hopefully RTS chimes in. IF the panel is supposed to be listed in the Alarm/Lock section I probably won’t get much out of it given the scenes I have set up but it would be nice.
