is there any way to have this run natively on a Qnap Nas or turn the java file a qpkg file to auto install on the nas?
Qnap Stephane on the qnap forum was able to do this for the HABRIDGE but doesnt look like there is enough demand on the forum for him to work on this one at this stage, not sure if you this experience in this or able to help Richard?
I would love Vera Concierge for QNAP.
I have been using HA Bridge, but now when Google has closed the door to link HA bridge (as Philips Hue), this is even better!
PS. I am already running Vera Concierge on my QNAP without qpkg (just putting the files in web folder, but I rather use qpkg!
Not as simple as a qpkg, but I have succeeded in running the Vera Concierge .jar in a Linux VM running under QNAP’s Virtualization Station. I used the following discussion for guidance: http://forums.whirlpool.net.au/archive/2671494
I’m a total Linux nube, so if I could figure this out then anybody can
update-rc.d conciergeserver defaults
chmod
service conciergeserver start
[/li]
[li][/li][/ul]
Although it turns out that a linux-side browser is not necessary so I could have skipped installing elinks.
Next I edited /etc/hosts and set localhost to the ip of my NAS server/virtual switch and VeraConcierge to a static ip for the Vera Concierge server. After reboot I was able to launch Vera Concierge from my PC’s browser using:
https://<VeraConcierge.static.ip>:8989
