I am seeing very odd behavior. I’ve had my foscam up an running independently and could view it and listen on iSpy, firefox to the ip address, and on TinyCamPro on Android. I had trouble setting it on Vera and MCV was able to set it up so I can see it and control it in Vera UI6 (advanced page like UI5). However, since it has been set up on Vera, every time there is “significant” motion it causes the camera to reboot. This means it is unaccessable for half a minute and then does a horizontal scan before settling back in place. Has anyone seen this kind of behavior? Anything that you can suggest about correcting it? Thanks.
I figured out what was happening. I was hitting the limit of access feeds with the camera itself. It was running out of memory and causing it to reboot, just because I had too many sources viewing it simultaneously.
