Vera App ios Swedish letters
Is anybody else have wrong signs in app? The Swedish letters ??? is replaced by other signs. Borh in iphone app and Ipad app…
Hello,
I would like to let you know that we have created a support ticket for you regarding the issue you are experiencing. Please have a look at your email inbox.
I have the same problem/Mike
IOS 12.2, iPhone XR, App version 3.22
Same problem for me / Mats
Is this the issue that Sorin highlighted in the new App. Reduced connection times for all with loss of characters for those of you with ‘non-standard’ characters?
C
‘non-standard’ ;D ;D ;D I understand what you mean :slight_smile:
:slight_smile: No offence intended!
C
This is what it looks like
Well looks like it may be the same issue, but I’d not like to say for sure. @Sorin?
C
Yes, it is. I have the same problem.
Me too , same issue in Finland :slight_smile: I think iit started 2-3 weeks ago. So far only cosmetic problem for me.
Hi everyone, we’re so sorry about that.
Since the full implementation of the fix for this issue would take us some more time, and the initial issue was the much worse (inability to connect to the controller at all, from the app), the mobile team had to hotfix this with the caveat that you’re experiencing. The upcoming update that should be around the corner will include fixes for the app to read all the encodings.
Hi Sorin, as “markoe” pointed out, this is just cosmetic as far as I can determine./Mike
Thank you, mickesanda
An issue nonetheless and the team understands that, thank you for the patience.
same problem for letters with “^”, “'”, “?”
