Vera and NTP
I noticed in the release notes for 1183 that Vera must retrieve NTP after power failure to have time/clock.
This creates an issue where a power failure occurs and Internet access may not be available post-poweron…
Is there a way to a) configure the NTP server locally in the UI in Vera to point to a local NTP server on the LAN or b) have Vera honor DHCP Option 42 (NTP Servers) to have the NTP server provided via DHCP…
This would at least be better than having NO clock after power is restored and as such, no timer functionality…
You could change the configuration file for ntpclient (Vera V1) or check the settings for rdate (Vera V2):
http://forum.micasaverde.com/index.php?topic=5393.0
Related post:
http://forum.micasaverde.com/index.php?topic=4895.msg27078#msg27078
