VERA and multiple GC-100 devices
I have multiple IR devices in multiple rooms I want to control. Can I connect multiple GC-100 devices to VERA?
Yes you can.
Click on the GC-100 plugin > create another.
Make sure to assign different IP’s and check the serial ports if you use them as they will default to 4999 & 5000
JOD.
Thanks for the response :slight_smile: I appreciate it
