Hi All,
I know that Alexa/Vera doesn’t do locks unless you set it to allow them with a pin code, even the pin code approach doesn’t seem to work though. I have 3 Kwikset locks on my house connected to Vera. Using Alexa I can tell it to lock the individual doors, (no pin code needed) ie Alexa lock the front door, etc. As far as I can tell there is no command equivalent to Alexa lock all doors.
My goal here is to create a scene to basically shut the house down for the night:
Check/lock all doors
turn lights on in the master bedroom
adjust ceiling fans to night mode
etc, etc
Alexa will not as far as I can tell accept lock commands as part of a scene, even just to lock them. I can get Alexa to run a scene I created that works as long as it has no locks in it.
I found some Lua code on the forum that is supposed to allow you to lock the doors via a scene, but lua coding isn’t my strong point so I’m not sure if there is a problem with the code or if I’m putting it into a scene incorrectly. The code is, (where xx is the id of the lock):
Luup.call_action("urn:micasaverde-com:serviceId:DoorLock1,“SetTarget”,{newTargetValue = “1”}, xx)
Any assistance would be greatly appreciated.
Gordon
