I have just released a new Version of the Vera Alert Plugin for Vera 3 with major new functionality. It is backward compatible with the existing Plugin. If you have auto-upgrade it should download soon.
It’s still in MCV audit.
Major new functionality:
[ul][li]Your Device Notifications, and Scene Trigger notifications can be sent out via Vera Alerts with NO luup code required.
You can already add a message as a Command in a scene as part of the Advanced tab of the scene. Lots of options … with no Luup code.[/li]
[li]The message strings now support a generalized template syntax.
What does that mean ?
You can embed just about any data from and device in Vera into your message in a nicely formatted manner. Still a little complex … but I will post some simple examples later.[/li]
[li]Since I could send Vera Alert message on any Vera system notification, without needing Luup code I extended this to SMTP messaging as well. Through the Vera Alerts Plugin any notification can be sent to your Android AND/OR any SMTP email address.[/li]
[li]You can override the default message string for any notification and use some of the template features described above if you like.
This should make it easier to get the Vera Alerts Android app to speak a nice message when a notifcation happens.[/li][/ul]
I still have a few more things on the wish list … let me know what you think.
I marked the plugin Vera3 only because I no longer have a Vera2/UI4 setup to test.
I do not think I have dependencies on any UI5 only interfaces.
I have updated the web page with instructions and a zip file on how to download and install manually. Let me know (via email) if you have problems and I will help you through it.
[quote=“RichardTSchaefer, post:5, topic:173393”]I will have to look into this.
By no mew members do you mean End Users like your self or services like “Vera Alerts” ?[/quote]
Hi Richard,
I’m testing your Plug In. It seems more complete but more complex too.
Have many options that that require to me read carefully your manual. I would like to learn how to send Alerts to my Galaxy Note.
As I haven’t seen any info about luup code, can you tell me if is possible to change the subject of the Email.
Also, is more a Lua thing, but how can I add Line feed in my message. My massage is in the same line as the “Aux Message”.
Does it support HTML tags?
Would be nice a loud Siren Alarm in my Android when I detect something abnormal in my house.
Since I have Vera2 / UI4 I tried to manually install the VeraAlert files. (I already had the previous plugin installed).
But, when I upload the files, the .lua files don’t get compressed - that is they upload OK, but do not get the lzo file extension appended indicating that they have been compressed. Thus when the plugin loads it cant find those files.
I thought I had seen this before but I cannot remember what the solution was - and I have searched the forums.
