I added a notification to a new device, and after that performed a message override in Vera Alerts.
Now the alerts stopped working. I see a blue bar in the screen (Vera Edge UI7) with an error message: ERROR : Error in lua for scenes and events
If I try to send a testmessage directly from the Vera Alerst page, it does arrive.
Turn off auto update and only update when you are sure you want the latest software … and yes … as MCV keeps making changes that are NOT backwards compatible … there are often plugin versions that are tied to firmware versions.
