I have a UI5 Vera Alerts that has been sending notifications to a Sonos user for some time. Recently the notifications stopped.
I found that the UserID was missing from Vera Alerts and From Vera/MCV, although the profile for that user was still in Vera Alerts. Weird but whatever. I add the notification only user back to Vera/MCV user, but the user refused to show up in Vera Alerts. After a lot of fighting, I “upgraded” Vera alerts to v6.43 (30461) in an effort to reinstall Vera Alerts. Following the reinstall and a reboot, Vera Alerts sees the user, assigned the correct profile to the user and everything looks as it should/did. In Vera Alerts, I can manually send a notification to this user and it works.
But, when the notification is triggered by a device, it is sent to the Default Recipients instead of the proper user and there is an error in the log.
50 10/15/16 18:17:39.097 luup_log:62: VeraAlert:62:SendAlert:UsingDefaultRecipients:nil <0x2b50d000>
50 10/15/16 18:17:39.098 luup_log:62: VeraAlert:62:SendAlert:Msg:Whisper something to Z-Waver. <0x2b50d000>
01 10/15/16 18:17:39.098 LuaInterface::CallFunction_Job device 62 function SVeraAlert_VeraAlert1_DeviceNotification_job failed [string "module("L_VeraAlert", package.seeall)..."]:1246: bad argument #1 to 'gmatch' (string expected, got nil) <0x2b50d000>
01 10/15/16 18:17:39.099 Lua_Job::Run job#17 : dev:62 (0xfcafa8) P:50 S:0 failed <0x2b50d000>
Does anyone have a clue they can lend me?
