A couple months ago i switched to a vera plus from from a vera lite the vera lite would randomly error cannot write user data and turn off all my switches. When i switched to the vera plus i left out all unnecessary plugins vera alerts being one of them. When i knew it was stable i slowly added the plugins in making sure everything worked. I recently added vera alerts to my vera plus and as soon as i added vera alerts my linear garage door started going offline I unpaired and repaired still wouldn’t stay online but after i remove vera alerts and unpair and repair it it has not gone offline since so i think for some reason vera alerts was knocking it offline.
Does not seem logical to me that Vera Alerts would cause that as, if I understand correctly, your zwave device is going offline… seems like a zwave issue or an clsi problem with Vera showing devices offline that are actually fine.
try resetting the device status in to see if that fixes your issue…
luup.set_failure(false,###)
return true
replace ### with the device number.
