Hi – I just upgraded to v0.101.972 and saw that VeraAlerts is now supported. When opening the control panel, I got errors (screenshot is attached).
Just FYI
Just FYI
Same thing here. But the Control, Profiles and Register tabs do seem to render properly for me.
[quote=“tedp, post:1, topic:190036”]Hi – I just upgraded to v0.101.972 and saw that VeraAlerts is now supported. When opening the control panel, I got errors (screenshot is attached).
Just FYI[/quote]
you need v>=981
I do not fully support VeraAlert, it is too complex and makes use of internal API of UI5/7 ( like PLEG ) so these will probably never work fine on ALTUI but with 981 it should display better and even , maybe functional for some features ( not using it so not tested fully )
You are correct. I must not have properly refreshed the browser. Looks good!
Sent from my Moto X using Tapatalk
