The following is the version history:
6.10 - Android 6.0 Privilege handling
Support Vera Mixed case accounts (new for UI7)
Fix Deleting Sound Files
6.05 - Move startup processing to background thread.
Changes to support tasker.
4.11 Allow Non Vera Cameras to be attached to messages.
Use {Picture(URL)} or {Video(URL, Seconds)} (URL’s are accessed from Vera)
Support URL links in messages. {url:YourURL} or {url:YourURL;Description} (URL’s are accessed from Android Device)
4.09 Finally found and corrected the problem of corrupted Notification Display.
4.08 Add Support for Font Size preference
Periodically reset LAN mode
4.05 Increase timeout talking to MCV servers.
4.01 Add Support for Picture Access for UI6 and UI7
Add Support for Pictures from multiple Veras. (Needs most recent Vera Plugin).
3.3 Fix quiet time. (Previously would only work if times were in the AM).
Cleanup Sound File Editor
Hopefully fix the blanks(white display) that some people have reported in the notification list.
Support Google TV.
3.2 Add MaxDays Retention
Add Badge for Samsung Touchwiz
Fix Bugs in Sending Video from Vera Alerts Plugin
3.13 Allow Support For Multiple Images per Alert
Allow Realtime Snapshot or Video Capture (Initiated from Previous Videos or SnapShots)
Allow Pan/Tilt options during real-time Video Capture.
Save SnapShot or real-time Video Capture
Zoom/Scroll Review Forward/Backwards in time from Event Videos or real-time Video Capture.
3.12 Quite → Quiet
Trap exceptions for Interger.ParseInt in Settings
Change FileNames in PhotoSnap to include hyphens
3.11 Dutch(nl) @ Da_JoJo
Fix bug in Tasker Startup
3.10 Portuguese(pt) Luis A Salvador drossivix@gmail.com@luissalvador
Integration With Tasker (Respond to Events and Change Settings)
Quite Time
Licensing Timeout (1 time per 8 hrs)
3.0.7- French(fr) Localization by @LG Loïc Guézennec loic.guezennec@free.fr
Danish(da) Localization by C E Sander @svaleb ces@post3.tele.dk
Spanish(es) Localization by Oscar del Rio B. , odelrio@vreo.net, @Vreo
Dutch(nl) @
Some logging cleanup
Fixed Image Viewer Window (Option to Save a snap or video, constraints zoom and pan)
3.0.6 - Allow local access for Pictures
3.0.5 - Beef up tracing
3.0.4 - Display ActionBar
3.0.3 - This fixes a number of configuration related bugs needed for Pictures and Videos to work.
Adds Tracing
3.0.2 - Connection Logic Rework - Lookup forwarding servers
3.0.1 - Pictures and Snapshots
2.4 - Improved UI, Now supports two levels of expanded list. Top level is based on Sorting Options.
Local Area Wifi-Network Processing … No GCM needed .
Earcon - support
Add Pause in message, units are ms.
Support for {tone:none} … No Alert tone, No TTS
Hi Richard
I am still having issues with receiving pictures with this latest version…I tried turning on the debugging options but the vera alerts folder is empty
I also tried your new HAL app and that is not working for me either
I have tried both apps on both of my Android devices (galaxy s2 and Asus tf300)
I develop and test on an S2 and S3.
On my S2 the directory is /sdcard/VeraAlerts
I believe it’s device/version specific the path for the sdcard (/sdcard for me).
I wonder if I am missing a privilege for writing a log file … You did find the VeraAlerts directory on your SDCard ? If it could create the directory … It should be able to create the file. In fact it creates the directory when it’s trying to write the file.
I test by sending a message from the Vera Alerts plugin:
Test {Picture(87)}
Where 87 is the device ID of one of my cameras.
If you have TTS option enabled on the Phone it should also tell you if you have connection problems.
Both apps seem to crash before or as the log is written
The hal app does not behave like your demo video…some options are missing and some buttons don’t work and the Vera alerts app has no way to access the menu on my transformer tablet on 4.2
I had removed the Title bar at the top to save on screen space for Android version 2.x
But when I upgraded to version 3.0 … I was required to add it back for devices that do not have a Menu button.
I just made another update.
No, I still cannot make the pictures work.
At one point I could coose between films or vera alert to open pictures, but it was empty.
Now I dont get this option.
There ie a file on the sdcard saying pictures vera alert, it seems to be empty, and “no program to open this file”.
Regards
CE
[quote=“svaleb”]No, I still cannot make the pictures work.
Regards
CE[/quote]
+1
I have the same issues with this new release
More improvements to debug tracing … I had some initialization problems for the tracing.
Also I added support for the camera to use LAN if you are testing at home …
This will eliminate the path through the MCV servers Hopefully the combo changes will allow
pictures (and video) to get through and if not … I will have some idea why …
I appreciate your patience …
Do not POST the log file … if remote … it will have a password. Edit it … and/or mail it to me personally.
Ok getting somewhere
The new release i can access the picture screen now without crashing and I now have an empty file in pictures/veraalerts filename “@58A”
I received a log file … and a confirmation … the problem is not on the Android side …
I have a problem on the Vera Side creating the snapshot at the time of the event.
If you login to Vera you should see some zero length files in /tmp/log/cmh/va.*.jpg
I just installed 3.07 and I’m still having a problem I have had for awhile. The text of the alerts do not appear on the Vera Alerts app screen. The text does appear in the notification bar and notification area when the alert is sent. So I know it is getting sent successfully. But the Vera Alerts screen shows only timestamps. I have browsed the forum looking for similar issues and didn’t find any. Hopefully someone can tell me what I am doing wrong. Droid Razr Maxx running Android 4.0.4
Yes, did that. What I get is a list of date & time stamps on the right, blank on the left. Same thing if I open any of the other days. Sometimes, rarely, I see text along with the most recent time stamp. But if I look a few minutes later that text is gone leaving just the time stamp.
