Vera Alerts and keypad pin codes
Hi -
I’ve got a yale deadbolt lock set up in my Vera and have almost everything working really well with Vera Alerts. The only problem I’m having, and can’t pinpoint whether its Vera Alerts or the Vera, is that in the Notifications of the door lock I can create a notification based on a valid pin being entered and can put an * into the field where it wants the Pin Code Index Number. This should give me a notification for all pin codes entered. When I receive the email notification it tells me which person’s pin code was entered. When I receive the push notification from Vera Alerts it tells me that “Pin Code #B” was entered. In Vera Alerts I’m using “Event=“Vera Alert”,Description=”{Message}“”
Is it possible that {Message} isn’t parsing the actual message correctly?
Thanks,
Pat
