I am trying to have a verbal announcement each time one of the alarm sensors is tripped in my house. For example, when the front door is opened, there would be an announcement stating “Front door open”. I have my Honeywell Ademco Vista alarm panel connected to my Vera Lite via an AD2USB with the Honeywell Ademco Vista Alarm Panels Plugin on the Vera. The senors all work well in the Vera. Now, I am trying to use Vera Alerts to send an announcement to an Android tablet that will be permanently mounted in the house. I have installed the Vera Alerts Plugin on the Vera and the Android app on the tablet. The plan is to have one scene with triggers for each sensor that will send a notification when the sensor is tripped. The notification is sent using the Luup event in the trigger with the following code:
I have created the sensor and some test triggers. The notification gets sent, but the issue is that it repeats approximately every 4 seconds until the sensor is closed. The Message Repeat Count in the Android app is set to 0, so I do not think it is the cause. Plus, I have tried making a test trigger with an Z-wave appliance module as the trigger (instead of an alarm sensor) and it makes the announcement only once. So my thoughts are that the sensor/panel is repeatedly sending an open signal until it is closed, which is repeatedly triggering; the announcements stop within seconds of the sensor being closed.
Any suggestions on how to fix this? I would like Vera Alerts to make only one announcement when an alarm sensor is tripped.
I was experiencing something similar, but it would repeat every 15 minutes or so. Since then, I bought a VeraAlerts license, and the problem seems to have gone away. I’m not sure if and how they can be related, but it may work for you. A license is not very expensive.
I got it working by using PLEG. I made an input for each sensor, then a condition for that input, and put the code from my earlier post into the Luup tab in the Action screen. Now it just makes one announcement! I still need to input all the sensors (I have 20+ sensors), but at least it is working for the couple trial ones.
Richard, do I need to create a separate input, condition, and action for each sensor or can you suggest a trick/short cut in PLEG?
I just upgraded to the VeraPlus, and I’m a huge fan of VeraAlerts. Ever since I added an alert when a door is opened, etc, I sometimes get multiple alerts sent to my devices. This doesn’t always happen. I’d say it happens once every 3 times or so. It just started after I upgraded. My VeraLite was working fine. I’m using the Ecolink door/windows sensors, and this is happening on more than one of them.
Vera Alerts sends an ALERT every time the device is triggered … If the device bounces the tigger
(i.e. tripped, untripped, tripped, untripped, …) in rapid succession you will get an alert for EACH trip.
You can use PLEG to debounce the trigger.
In PLEG
Input:
NoisyTrigger1 when some noisy Trigger trips
It is TRUE ONLY if there has been at least 30 seconds between the last two events (i.e. the current one and the previous one).
In a burst, the first one will always be true, and the rest will be false until it is quiet again for 30 seconds.
[hr]
NOTE: This is also useful in the opposite sense if you have a switch with instant status and you want to detect when the user has turned the switch on and off and on to potentially trigger a different behavior:
DoubleClick LightSwitch @ 2 < 30
Here, you must get two events in LESS than 30 seconds, otherwise they are considered unrelated events.
