I have managed to configure my Vera Alerts on Android and my VeraAlerts device on Vera so they seem to work. Every time my Vera restarts i have a message on my mobile from Vera Alerts. So far so good. But now i am trying to have other notifications (armed window sensors etc) sent to Vera Alerts too. I must have missed something, as the notifications go out by email, but they do not go throught to Vera Alerts. They are all set up there, and in profile it is set up, also in the settings tab i have Vera-Alerts-Mobil Profile ticked
Solution:
Go to Vera Alerts Plugin Settings.
- Make Sure Process Notifications is selected.
- For each user on LEFT side make sure there is a profile selected on RIGHT side
Go to Vera Alerts Notification Configuration page.
You actually need to do this when you add/delete/change any notification in Vera.
Save if indicated!
Now you can stop the MCV email message by logging on to the USER on the MCV servers (cp.mios.com (UI5) or home.getvera.com (ui6) and disable emails for that particular user.
Yes that worked. I had not ticked a profile with the user. It looked as if i did, but when i clicked that user the profile was unticked. The first notifications took a couple of minutes to come through, i thought it is not working. Then i had 4 or 5 within a few seconds. Every one sine has come more or less immediately.
Same here.
The line “For each user on LEFT side make sure there is a profile selected on RIGHT side” needs to be keenly understood. Don’t just look at the settings for the Default, but click on each user for the profile selection.
Now happy here. ![]()
