VERA 802.11 G module
Does anyone know if VERA work sitting next other competing 802.11 device and will both do their own thing?
Mine does no problem, but then again there are thousands of WiFi devices and you can bet that there are some that don’t play nice together.
Do you have a problem with WiFi? If you do then there are normally some settings that can help. Or you can turn Vera’s WiFi off altogether!
Thank you, I will you know if there are incapability issue. Currently using Apple products and since they are in bed with Vera i suspect if there are any problems they will provide a fix. (Power of positive Thought)
One of my friends has his Vera and an apple airport/timemachine stacked one on top of the other. Both have WiFi on so you should be OK!
