Vera 7.31 Core Firmware BETA Release
Stupid thought: under settings, zwave there is an optional to set “ Number of seconds to wait to start polling” and The default is 20 seconds. Could it be related?
No. This has nothing to do with polling. The setting you speak of is a delay after a luup reload before polling cycles start.
Thx for the explaination
It’s not a typo and we don’t have any quick fix for this that we can integrate in 7.31. It is an old issue, we’re looking into it for the next release(7.32). It would help us if you can send a verbose logs when this happens (PM).
Thanks Eduard. I will toggle my verbose logs and PM you the relevant entries.
It’s good to hear that you guys know about it and are looking into it.
Welcome back edward! Glad theres someone looking into vera and not ezlo :+1:
PM’d you with the log extract.
Hey @Gabi @edward Is there any way to include a Zigbee stack update in the next firmware?
I think it is rather a more complete stack support on the software side (luup engine) which would be helpful rather than just updating the stack (zigbee chip firmware). I could be wrong but from what I see from the ember zigbee stack, a lot of end points show up but don’t have a corresponding device on the vera. Example pressure sensor…
Oh yeah can u guys make the factory reset funtion actually work after 6 button presses, sometime it takes 3 days of doing it before it actually works
New Beta available (check the BETA 2 post)
We have a new Beta available for Vera Edge with fixes on the issues reported after the first beta release.The update for Vera Plus and Vera Secure will come early next week.
Vera Edge: https://dl.mios.com/rl/LIVE/731/mt7620a_Luup_ui7-1.7.4954-en-mios.squashfs
Fixes:
  • Fixed the issues with the view live image and video recording not working on IP Cameras.
  • Fixed the issue with auto-update option being unchecked after plugin update.
Known issues: Unable to manually change day/night extra setting on Vistacam 700 from the Web UI and issue with an error message being displayed when trying to update Weather Settings without changing Temperature Format.
Ok, short version. I have had LOADS of issues on my zwave network. Vera support helped me in a 2 x 1.5 Hr session and summarized they did:
  1. re flash my zwave firmware (v6)
  2. advised me to go to FW 7.31 (You are running the latest version 1.7.4902 (7.31))
since I have had issue as well, but other issues, less issues. Including is now possible again but I would say a 30-40% failures rate (but compared to 100% this is acceptable).
i still have issues that multiple devices still do not send status back to Vera although vera can control them successfully.
And after having tried to include a simple Qubino ZMNHCD1 with a temperature sensor attached Vera consequently gives me not 2 but 4 devices, and it should only give a shutter and temp sensor (have multiple of these devices included in previous firmwares:
I am trying to further contact Vera support, but that is also a challenge :slight_smile:
Hi
Seems pairing Sensative strips is currently broken as I discovered for myself today here. My Vera Plus is on firmware version 1.7.4453
Was this issue picked up for a fix in any of these beta versions?
Thanks.
Hello,
We have a new Beta available also for Vera Plus. Please check the Beta 2 Post
The update for Vera Secure will come in the next 1-2 days.
We have the Beta 2 available also for Vera Secure, please check the Beta 2 Post
Upgraded last night and all systems go.
that’s the same issue i have with the Zooz ZEN30 devices, but they just tell me they are not supported… would think that a dimmer and switch would not need some special integration, but what do i know.
I use some Sensative strips on my Vera Plus running firmware 1.7.2935. And have some new ones on the shelf. I plan to do an upgrade when 7.31 is going officially live. How to solve this ? Should I first include the new ones when still running 1.7.2935 and then upgrade ? Will they remain working then ?
If they pair and configure on that version I’d pair them now.
I do have two other strips and they are still working OK on the latest firmware my Vera Plus is on.
I just couldn’t pair a third strip last week.
I recently updated to
You are running the latest version 1.7.4970 (7.31)
and now I have 3 lights in the house that click, with the little blue LED constantly blinking, and the light will not turn on. How do I fix this?
