My vera 3 system has been working fine for a year, connected a a switch through LAN port of home Netgear router. To try to better understand the configuration I hooked the vera 3 to another home router…DLINK. It worked fine, but when I took it back to the original Netgear it would not configure. So, I tried holding down the vera 3 Power Button to reset it. Until then it had always came up blinking the power light and eventually turning GREEN. Now it comes on and the POWER light turns ORANGE after about 30 seconds. It stays SOLID ORANGE. How do I correct this situation ??
Ed
