I just opened the box on a vera 3 and plugged it in. All seemed to be going as planned. I did the upgrade and then wanted to go to INCLUDE mode. It would not do it.
Fortunately, I bought 2 and did not need the second one yet, but I will need it active soon.
The second vera3 went into include and I went through the process fairly quickly.
What should I do to try and get the first one into INCLUDE mode??
Also, note that the battery pack does not work on this one either.
Please provide more detail. Are you getting any error message on the Vera unit’s UI when trying to go into include? Did you charge the batter pack? I believe the battery back has to be switched on for it to charge. I have no use for the battery back. But a search in the forum may find more info.
There is really nothing else to say. The only thing that I did differently was to allow the first attempt to update before trying to go to INCLUDE mode. When I try to TAP the zwave button, the light goes off and stays off. It never goes to slowly flashing for INCLUDE.
Can you try to go into include mode when the vera unit is connected to the network and you have the vera web UI loaded to see if any error messages display at the top center.
Your zwave chip is not the primary controller. Your role needs to specify this:
Role Master SIS:NO PRI:YES
You will need to go into the zwave settings and try to make the zwave chip the primary controller. I do not have access to my vera unit at the moment, so I can not list the steps.
