I have a Vera 3 server setup which includes a total of 45-50 Fibaro devices (On/Off, door sensor, etc.). The devices are located in a house (Ground + 2 floors). The server is located on the first floor.
When I execute scenes which include devices on the second floor, the lights on the second floor turn on after around 2 seconds.
Do I need to configure each node again and then heal the network to get the optimized z-wave mesh network?
Since the network I am working on is a huge one (in terms of number of devices), will running the repair / heal process after everything is setup help? Will this reconfigure all the devices and setup an optimize mesh network?
same here… turned out to be a line of luup that tries to reach a webserver (my pc) which was not running and kept reloading the vera after running the scene with the code.
repair / heal is being run everyday automaticly but after some changes to z-wave devices it sometimes helps to do it manually. you can also press the device settings > device options > update neighbour nodes this probably is a lot faster then heal a huge network as u have
