That sounds far more plausible.
Thanks for the replies. Yes, cj answered all of my questions. I will change programs and retry this weekend.
I successfully connected via the serial pins (made many mistakes on my part, i’m new at this)
it looks like the constant green light issue is caused by a CRC error. I’m hoping cj will help me walk through replacing the os. I will post my progress in this thread.
3: System Boot system code via Flash.
Booting image at bc0f0000 …
Image Name: MIPS OpenWrt Linux-2.6.37.1
Created: 2011-10-26 15:01:23 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 875710 Bytes = 855.2 kB
Load Address: 80000000
Entry Point: 80000000
… Verifying Checksum … Bad Data CRC
Special thank you to cj for supporting me! The constant green light issue has been put to rest. I added my first zwave device and everything is working swimmingly.
The CRC error was fixed by flashing a new firmware. The method I used is not fully tested and therefore not published yet. It worked great for me. If you are experiencing the constant green light, there is an easy fix. Until the fix is published, I don’t think I should share the info here.
I found my help here: http://forum.micasaverde.com/index.php/topic,9027.0.html
My guess its the same or very similar to the V2 recovery:
