Vera 2 - U14 not responding
The unit communicates properly to all my existing devices and executes my scenes but it won’t allow me to add another device. Following the steps to add a device, I brought the unit to the light switch I’m trying to add, connected the unit to power (used both a fully charged power pack and used an extension cord for direct power - neither worked). It took about 2 or 3 minutes before the Zwave light came on solid. I pressed the Zwave button on the back of the unit and nothing happens. The light does not start to blink so its not going into the “include” mode. I’m stuck. The Dashboard says the unit is working with the latest firmware version. I’ve done everything I can think of including the reset button on back. Does anyone have an idea?
You may be encountering a resource issue with the unit. Without specific details on what you have on your unit, it is hard to advise you.
You may want to set up you unit to log to USB and set up an external usb swap partition. Both subjects are covered on the forum.
http://forum.micasaverde.com/index.php?topic=8883
Thanks a lot for your research and reply. Unfortunately, that kind of programming is waay beyond me. Connected to the Vera 2 are 2 Trane t-stats, 2 Smart switches and 2 GE plug in dimmers - 6 devices in total. Doesn’t seem too many to me. Maybe it’s time to upgrade to the Vera 3.
