Vera 2 not transmitting commands/ Device failed to configure
Please check the attached image of error i am getting on dash board. I am not being able to understand the reason for it.
The current error’s i am getiing are ‘Configure Node 102’ ‘Configure Node 103’ ‘Unable to get information on node’
My system was working fine accessing it through Square Remote HD & Dashboard. The malfunction happened suddenly during trying to configure Home buddy on my android device.
Mine was doing something similar until I changed z-wave settings to UNCHECK ‘use vera routing instead of z-wave’ recently. Seems like I used to have it checked for the longest time, but since unchecking this it has been good.
Did you mean to say “Use MiOS routing instead of Z-Wave (requires 4.5)” I just unchecked it. I hope it helps me. Thanks.
Probably; they changed the wording along the way in UI5.
