Good day to all. This is my first post. I have a new home and vera 2 system. I would like to monitor the energy consumption of my heat pump water heater. Is there a device that is supported by the vera 2 to do this?
Thanks,
Jim
Thanks,
Jim
What kind of outlet does it use and what is its power rating? Something like this switch might work. No wiring required and it monitors energy consumption of whatever is plugged into it (up to 1875W, 15A). It also give you on/off control.
Or you could use an energy monitor like this AEON labs clamp monitor. It takes a little bit of configuring and you’d have to be able to separate the conductors in your heat pump’s power cable.
