V1.92 has been released, containing a few small bug fixes:
Fixes issue with swiping between screens, when using an iPad lying flat on its back
Support for SimpleAlarm plugin
Error messages about incorrect credentials will now only be shown once, until the app is restarted or network settings are changed.
Settings not applicable to the type of device (iPhone / iPad) are now hidden in the settings screen.
Action controls can now be linked to a Vera (in the control’s Properties) so that Lua commands can be sent to the correct Vera in case there is more than one.
and I’d like to run this check periodically and get an alert if veralite is down.
Is it possible ?
Tnks
Donato[/quote]
An issue with this is that your Vera will not always use the same forward server. It may use fwd8.mios.com right now, but if a luup restart or a vera restart happens, it may / can change do a different server.
Is it possible ?
Tnks
Donato[/quote]
Garrett[/quote]
Hi Garrett ok tnks for your reply.
Then is it possible to have an action that check periodically the vera system based on userid, psw and device with the same parameters used by Homewave to connect remotely .
The action button currently does not support this. It can send lu_action commands to Vera, using the same credentials and forward server that HomeWave uses to connect. But it cannot do a lu_alive, nor will it read and report any data.
I am having bad issues with 1.92 on my ATT iPhone 4S.
The program worked great until this latest update. I am currently running IOS 6.1.2.
I have deleted and re installed. Worked great for a moment. It hangs and shuts down at viewing main screen. When it does work, it will only receive updates from 1 of the 3 thermostats I have a single ui6 Veralite monitoring.
My ipad mini, running IOS 7.0.4, is unable to receive any updates from the 2nd and 3rd thermostats. It is connected on the same lan, with direct IP connection to the Veralite.
After trying and owning most, if not all, of the IOS remote control software available, I can say HomeWave rocks. Not perfect, specially flakiness around the status of devices and limited set of available icons. However, very solid effort
Looking forward to the next version!
JR
