I’m a newbie, but catching on quick ![]()
I picked up 2 Utilitech wireless water leak detectors today at Lowes Model #TST01-1. They can be used with Iris or any Z-wave device. I have the Vera3 so I should be good to go.
It took a couple times and some patience to connect the device. You can find another thread that explains this a little further
[url=http://forum.micasaverde.com/index.php/topic,15850.msg120725.html#msg120725]http://forum.micasaverde.com/index.php/topic,15850.msg120725.html#msg120725[/url]
So now that I have it hooked up, it recognizes it as a motion sensor, which I think is correct. I tried testing it by touching the two prongs into a glass of water. the device starts to beep. It will quit when i take it out of the water.
The problem is looking at my system of devices, I see that the indicator does not move nor anything happens to say that it was tripped.
Does anyone have any experience with this device and know how to get it working with Vera3 UI5?
Thanks, Kurt
