AK, I am hoping you can shed some light on whether an extended SOAP subscription effects program execution in openLuup. There is a short thread on similar here: http://forum.micasaverde.com/index.php/topic,14664.msg111226.html#msg111226 but there did not seem to be any resolution over how program flow is effected by a daemon listening for an http response. I’ll outline what I am doing below as I am sure there are many people who are interested in using listeners/onvif commands for soap events.
Here is the background of what I am doing. I have an onvif enabled camera that has internal motion detection. I can get the capabilities of the camera using the SOAP call:
<s:Envelope
xmlns:s="http://www.w3.org/2003/05/soap-envelope">
<s:Body
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<GetCapabilities
xmlns="http://www.onvif.org/ver10/device/wsdl"/>
</s:Body>
</s:Envelope>
I place the XML in a post command after right click opening the “show request editor” in SOAPUI: https://www.soapui.org/ SOAPUI takes care of authentication, headers and encoding.
Using the WSDLs embedded in the return XML, I then send a pullmessages request:
<SOAP-ENV:Envelope
xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope"
xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding"
xmlns:wsa="http://schemas.xmlsoap.org/ws/2004/08/addressing"
xmlns:wsdd="http://schemas.xmlsoap.org/ws/2005/04/discovery"
xmlns:chan="http://schemas.microsoft.com/ws/2005/02/duplex"
xmlns:wsa5="http://www.w3.org/2005/08/addressing"
xmlns:xmime="http://www.w3.org/2005/05/xmlmime"
xmlns:xop="http://www.w3.org/2004/08/xop/include"
xmlns:wsrfbf="http://docs.oasis-open.org/wsrf/bf-2"
xmlns:tt="http://www.onvif.org/ver10/schema"
xmlns:wstop="http://docs.oasis-open.org/wsn/t-1"
xmlns:wsrfr="http://docs.oasis-open.org/wsrf/r-2"
xmlns:ns1="http://www.onvif.org/ver10/actionengine/wsdl"
xmlns:tad="http://www.onvif.org/ver10/analyticsdevice/wsdl"
xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl"
xmlns:tdn="http://www.onvif.org/ver10/network/wsdl"
xmlns:tds="http://www.onvif.org/ver10/device/wsdl"
xmlns:tev="http://www.onvif.org/ver10/events/wsdl"
xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2"
xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#"
xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd"
xmlns:xenc="http://www.w3.org/2001/04/xmlenc#"
xmlns:wsc="http://schemas.xmlsoap.org/ws/2005/02/sc"
xmlns:ds="http://www.w3.org/2000/09/xmldsig#"
xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"
xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl"
xmlns:tls="http://www.onvif.org/ver10/display/wsdl"
xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl"
xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl"
xmlns:trc="http://www.onvif.org/ver10/recording/wsdl"
xmlns:trp="http://www.onvif.org/ver10/replay/wsdl"
xmlns:trt="http://www.onvif.org/ver10/media/wsdl"
xmlns:trv="http://www.onvif.org/ver10/receiver/wsdl"
xmlns:ter="http://www.onvif.org/ver10/error"
xmlns:tse="http://www.onvif.org/ver10/search/wsdl"
xmlns:tns1="http://www.onvif.org/ver10/topics">
<SOAP-ENV:Header>
<wsa:Action>http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesRequest</wsa:Action>
<wsa:To>http://10.17.4.25/onvif/subscription?idx=4</wsa:To>
</SOAP-ENV:Header>
<SOAP-ENV:Body>
<tev:PullMessages>
<tev:Timeout>PT59S</tev:Timeout>
<tev:MessageLimit>100</tev:MessageLimit>
</tev:PullMessages>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
This gets me a return XML file with an embedded motion detection message.
<SOAP-ENV:Header>
<wsa:To SOAP-ENV:mustUnderstand="true">http://10.17.4.25/onvif/subscription?idx=4</wsa:To>
<wsa:Action SOAP-ENV:mustUnderstand="true">http://www.onvif.org/ver10/events/wsdl/PullPointSubscription/PullMessagesRequest</wsa:Action>
</SOAP-ENV:Header>
<SOAP-ENV:Body>
<tev:PullMessagesResponse>
<tev:CurrentTime>2018-11-08T13:39:08Z</tev:CurrentTime>
<tev:TerminationTime>2018-11-09T00:25:06Z</tev:TerminationTime>
<wsnt:NotificationMessage>
<wsnt:SubscriptionReference>
<wsa5:Address>urn:uuid:1419d68a-1dd2-11b2-a105-00023EB2006A</wsa5:Address>
</wsnt:SubscriptionReference>
<wsnt:Topic Dialect="http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet">tns1:RuleEngine/CellMotionDetector/Motion//.</wsnt:Topic>
<wsnt:ProducerReference>
</wsnt:ProducerReference>
<wsnt:Message>
<tt:Message UtcTime="2018-11-08T13:39:08">
<tt:Source>
<tt:SimpleItem Name="VideoSourceConfigurationToken" Value="VideoSourceMain"/>
<tt:SimpleItem Name="VideoAnalyticsConfigurationToken" Value="VideoAnalyticsToken"/>
<tt:SimpleItem Name="Rule" Value="MotionInDefinedCells"/>
</tt:Source>
<tt:Data>
<tt:SimpleItem Name="IsMotion" Value="true"/>
</tt:Data>
</tt:Message>
</wsnt:Message>
</wsnt:NotificationMessage>
</tev:PullMessagesResponse>
</SOAP-ENV:Body>
I can change the tev:TimeoutPT59S</tev:Timeout> setting of 59 seconds in the pullmessages request to tev:TimeoutPT4H</tev:Timeout> four hours where the camera will wait for 4 hours for a motion event. If a motion event occurs, the soap subscription is terminated after sending its motion message, and I then have to resend the pullrequest to reestablish the connection.
In general, my question concerns two things: Will openluup deadlock on a long wait–say several hours. If yes, I can shorten the wait for another pullrequest to 30 seconds or less, but then the daemon must send a new pullrequest every 30 seconds and I’m not confident that frequent messaging won’t crash the camera.
Is an http listener in openluup the right way to go. If so, do you have any suggestions on implementation/callback routines.
As always, thx in advance for your time here.
