Using Vera Edge UI7 already some time, but only the standard available possibilities. No knowledge of Luup, Lua or PLEG.
I am wondering if there is a plugin (or somebody capable of creating one) that turns scenes into a devices. This would enable the use of the same (only once created) scenes in different situations or triggers. Or am I thinking completely wrong here? Anybody to point me in the right direction? Simple answer like: Get to know PLEG you fool, is also ok…
HouseModes Plugin…I think is what you are looking for. Gives you a “device” that has the various house modes. So you could set up scenes based on modes and devices can trigger a mode switch…etc…
…and yes…PLEG… but I don’t know anything about PLEG.
