I have multiple Leviton rf+ scene controllers and also an Evolve LCD1. I use scene triggers for the Evolve since the scene tab in the current control doesn’t allow you to select scenes like the Levitons do.
This got me thinking… Is using the Scene Tab in the control effectively the same as setting a trigger in the scene? Is one more reliable than the other?
My Levitons are pretty flakey, sometimes they work in a split second, other times it could take 10 seconds… and sometimes they just don’t work. I’ve set one to use triggers in a scene instead of assigning scenes in the control scenes tab and it appears to be more reliable.
More curious than anything else about the difference between the two.
Thanks.
