I have a VeraPlus and am trying to integrate the Nest Thermostat in a scene, but I’m having issues… Hopefully someone here will be able to help.
When creating a scene, I can’t set the temperature… The up and down do not work at all. My intention is to set a different temperature for bed time vs. the “away” time in a scene with the WWN plug-in. Is that supported? How would I go about doing this?
If this is not a supported function for this plug-in, I would rather give up on the Nest and get a different thermostat which I can better control through VeraPlus. What would be a good alternative?
I found the WWN plugin to be sluggish and not as snappy to use as the alternative one in the app store.
Search the store for “Nest Thermostat and Protect”.
Don’t give up on the Nest just yet as it can work brilliantly with Vera.
I use Home /Away/Night Vacation modes in Vera to set the Nest as I like it. But I found that the best way to use it for temperature control is with a couple of scenes - one that turns it up one degree and one down a degree. I call these scenes “It’s too cold” & “It’s too hot”. They work brilliantly via Siri and homebridge because at the end of the day who cares what the temperature actually is? It can only be either too cold, too hot or just right
Not being an expert in Lua, I don’t see anything wrong with this code, but when I use it in a scene, the Vera strips the “+” (and only the +) and gives a script error. I’ve tried it multiple time, and the result is the same.
Did this “Nest Thermostat and Protect” plugin get pulled from the store? When I search Nest, I only see the WWN official plugin. The official plugin has issues.
It will not set a temperature when the Thermostat is in Auto [Cannot set target_temperature while mode is heat-cool]
Forces me to re-authorize
Complains that the Thermostat is offline when I am in any mode but Home
I would love to try something else that may be more stable and allow me to use the thermostat the way it was designed.
