I have a wall switch dimmer (Evolve) and a lamp dimmer plug-in module. I have a scene that will turn them both on to 60% (with the polling delay) and another scene to turn them off.
What I would like to do is if I change the dim level at the wall switch to say 40%, the lamp would also change to the same dimmer level. (after the polling delay)
Is that possible?
