hello!!!
On my vera lite running with UI5, I have it sync with a schlage zwave key pad. Where do I go to find out the history of the assigned codes that were used? Which code was used to access and when. it was so easy on the UI4 (with my Vera 2_). Thanks in advance for your help.
I have (2) vera 2s and 1 vera Lite. I am running UI4 on the vera 2s and UI5 on the vera lite. At this time I cannot connect to my vera 2s and will have to wait until I get to the rental homes to get access to these units.
