Use LightwaveRF switch to initiate another event
I have a standard lightwaveRF dimmer switch. I have it paired to a Vera and RFX module.
It works well, but I would like to use my switch to initiate other events. For example when I turn on the switch in my office it also turns on the PC and monitors. Is this possible?
Unfortunately the standard LightwaveRF dimmers (eg JSJSLW400) are only RF receivers, they don’t transmit any commands when you press their buttons.
You would need to use one of their wall mount transmitters (eg JSJSLW201 which replicates the dimmer controls or a JSJSLW101 mood controller)
