Use Http to obtain device status
Not sure which area to post this in… here goes
Hello all, I was hoping someone could help me with some syntax.
I’m trying to use http commands to get the on/off status of a Vera device. I found a few links but when I run them, I get a variable not found error. I have successfully used http to turn a device on and off, now I just need to find an http command which returns the on (1) or off (0) state of a switch, plug, etc.
Thank you!
http://wiki.micasaverde.com/index.php/Luup_Requests#variableget
http://ip_address:3480/data_request?id=variableget&DeviceNum=6&serviceId=urn:micasaverde-com:serviceId:SwitchPower1&Variable=Status
just add your device number and the ip of your vera
Thanks,
that is what I had found but when I enter my Vera local IP address and device # (I’ve also tried the altID), the http request just returns “error: variable not found”
Post your url.
http://10.0.1.10:3480/data_request?id=variableget&DeviceNum=1002&serviceId=urn:micasaverde-com:serviceId:SwitchPower1&Variable=Status
The service ID is incorrect… SwitchPower1 is urn:upnp-org:serviceId:SwitchPower1
So the correct URL should be:
http://10.0.1.10:3480/data_request?id=variableget&DeviceNum=1002&serviceId=urn:upnp-org:serviceId:SwitchPower1&Variable=Status
OMG. Thank you. I was beating my head against the wall!!!
