Does anyone know if it would be possible to load and run Vera concierge on an old Vera 3 I have laying around? Would anybody be able to provide me instructions for doing so if this is indeed possible? I don’t mind completely wiping the unit to make this work rather than by another piece of Hardware that may just do the same thing.
forgive my linux ignorance but do i have to wipe that whole machine or can i simply install in a new directory i will create using winSCP? Do i need to install java?
sorry, not my area of expertise but i can usually figure it out with a little help.
Yes to need to do the equivalent of the linux install as defined on my web page.
I have not tried … and not inclined to try … since the Vera 3 is a pretty low powered processor … and the environment is far from a standard linux … If you are not a linux hacker … I would not recommend it.
