I am connecting a 2GB USB stick to my Veralite via a powered USB hub. The hub seems to be working OK, since my RFXtrx433 is plugged into the same hub and working great.
USB stick is 2GB, formatted to FAT32 (as per advice on another thread), named “2GB_STICK” (as per advice on another thread) and plugged in.
However, VERA doesn’t seem to find it… (1) it doesn’t show up in VERA Setup > Logs > USB status = Not mounted and (2) doesn’t show up in dataMine debug page
Log in via ssh and issue a ‘fdisk -l’. What does it show. Vera will not mount the usb stick automatically. You will have to take care of that yourself.
