I thought I’d post this as a tip to others frustrated with the network randomly failing after months of functioning fine.
I’ve had a vera 2 about 9 months. It worked beautifully for a couple months - maintenance free, then the network failed. ~30 nodes. It couldn’t talk to any except the one nearest the Vera. I reset the network re-added all the devices, and after several hours got it up and going again. Then after a couple months the same thing happened again. Out of frustration, I tried a Homeseer free trial with a laptop and a dongle, but it had the same problem! So I reset everything again and went back to my Vera 2 and it worked beautifully again … for a couple months.
This time I figured I need to see what’s going on, so I spent $60 on a “Ubiquiti USB 900MHz Spectrum Analyzer”.
With a centrally positioned Vera it was very slow to respond and was reaching the nearest ~15 of 30 nodes only, Heal didn’t help. I started noticing the outside lights on were left on when the sunset timer should have turned them off.
It turns out the spectrum analyzer showed high constant output - so I walked around to where it was strongest - a 2gig thermostat. I hit the reset button and voila! The output stopped and the whole network was good as new.
SO, if that sounds like a problem you’re having, I have to say it was $60 well spent. It also could help you track down any other source of interference.
