I believe I am having same issues, but was working fine for the last year with out issues. Now i get this
Errors log:
2014-11-11_00:19:45 CHECKDISK: Starting to check device: /dev/sda1 with: /usr/sbin/e2fsck
2014-11-11_00:19:57 (/dev/sda1) : Successfully repaired
2014-11-11_00:19:57 FAILED to mount USB stick: /dev/sda1.
2014-11-11_00:19:58 FAILED to mount USB stick: /dev/sda1.
2014-11-11_00:19:59 FAILED to mount USB stick: /dev/sda1.
2014-11-11_00:20:00 FAILED to mount USB stick: /dev/sda1.
2014-11-11_00:20:02 FAILED to mount USB stick: /dev/sda1.
2014-11-11_00:20:03 FAILED 5 times in a row to mount the usb stick. Trying to recover it.
2014-11-11_00:20:03 FAILED to mount USB stick: /dev/sda1.
2014-11-11_00:20:03 [recover_usb] CHECKDISK failed. Re-formating drive
2014-11-11_00:20:06 FAILED to mount USB stick: /dev/sda1.
2014-11-11_00:20:06 SUCCESS recovered UsbStick
2014-11-11_00:20:07 FAILED to mount USB stick: /dev/sda1.
2014-11-11_00:20:08 CRITICAL: Failed to mount the USB STICK.
root@MiOS_30002392:~# fdisk -l
Disk /dev/mtdblock0: 0 MB, 524288 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn’t contain a valid partition table
Disk /dev/sda: 2097 MB, 2097152000 bytes
65 heads, 62 sectors/track, 1016 cylinders
Units = cylinders of 4030 * 512 = 2063360 bytes
Device Boot Start End Blocks Id System
/dev/sda1 * 1 261 525914+ 83 Linux
/dev/sda2 262 1016 1521325 83 Linux
root@MiOS_30002392:~# lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 001 Device 003: ID 1908:1320
Bus 002 Device 001: ID 1d6b:0001
Bus 002 Device 002: ID 1a86:7523
root@MiOS_30002392:~# dmesg
Linux version 2.6.37.1 (builder@builder.micasaverde.com) (gcc version 4.3.3 (GCC) ) #2 Fri Feb 22 04:07:32 PST 2013
prom: fw_arg0=00000001, fw_arg1=87f46fb0, fw_arg2=07f473b0, fw_arg3=00000000
env[0]: memsize=128
env[1]: initrd_start=0x00000000
env[2]: initrd_size=0x0
env[3]: flash_start=0x00000000
env[4]: flash_size=0x2000000
env[0]: memsize=128
CPU revision is: 0001974c (MIPS 74Kc)
Ralink RT3883 ver:1 eco:5 running at 500.00 MHz
Determined physical RAM map:
memory: 08000000 @ 00000000 (usable)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 → 0x00008000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 → 0x00008000
On node 0 totalpages: 32768
free_area_init_node: node 0, pgdat 80249270, node_mem_map 81000000
Normal zone: 256 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 32512 pages, LIFO batch:7
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: console=ttyS1,57600 board=NA900 rootfstype=squashfs,jffs2
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
Writing ErrCtl register=00000000
Readback ErrCtl register=00000000
Memory: 127300k/131072k available (1890k kernel code, 3772k reserved, 451k data, 156k init, 0k highmem)
SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:48
console [ttyS1] enabled
Calibrating delay loop… 249.85 BogoMIPS (lpj=1249280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
NET: Registered protocol family 16
MIPS: machine is Sercomm NA900
bio: create slab at 0
i2c-gpio i2c-gpio: using pins 1 (SDA) and 2 (SCL)
Switching to clocksource MIPS
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
JFFS2 version 2.2 (NAND) (ZLIB) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
msgmni has been set to 248
io scheduler noop registered
io scheduler deadline registered (default)
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x10000500 (irq = 13) is a 16550A
serial8250: ttyS1 at MMIO 0x10000c00 (irq = 20) is a 16550A
ra_nand_probe: alloc 7f8, at 87841000 , btt(878415f8, 200), mtd:87841000
Creating 10 MTD partitions on “ramips-nand”:
0x000000000000-0x000000080000 : “u-boot”
0x000000080000-0x0000000a0000 : “config”
0x0000000a0000-0x0000000b0000 : “factory”
0x0000000b0000-0x0000000d0000 : “config_default”
0x0000000d0000-0x0000000f0000 : “user_storage”
0x0000000f0000-0x0000004f0000 : “kernel”
0x0000004f0000-0x000000cf0000 : “rootfs”
mtd: partition “rootfs” set to be root filesystem
0x000000cf0000-0x0000017f0000 : “rootfs_data”
0x0000017f0000-0x000001ff0000 : “mios”
0x000001ff0000-0x000002000000 : “pid”
ramips_mdio: probed
eth0: AR8236 switch driver attached.
rtc-s35390a 0-0030: rtc core: registered rtc-s35390a as rtc0
TCP westwood registered
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear greearb@candelatech.com
All bugs added by David S. Miller davem@redhat.com
rtc-s35390a 0-0030: setting system clock to 2014-11-11 05:19:24 UTC (1415683164)
VFS: Mounted root (squashfs filesystem) readonly on device 31:6.
Freeing unused kernel memory: 156k freed
input: gpio-buttons as /devices/platform/gpio-buttons/input/input0
Button Hotplug driver version 0.4.4
Registered led device: na9xx:red:power
Registered led device: na9xx:green:wan
Registered led device: na9xx:red:wifi
Registered led device: na9xx:green:wifi
Registered led device: na9xx:green:service
Registered led device: na9xx:green:lan
Registered led device: na9xx:green:zwave
Registered led device: na9xx:green:usb1
Registered led device: na9xx:green:usb2
eth0: link up (100Mbps/Full duplex)
JFFS2 notice: (484) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (0 unchecked, 0 orphan) and 6 of xref (0 dead, 0 orphan) found.
diag: Detected ‘Sercomm NA900’
device eth0.1 entered promiscuous mode
device eth0 entered promiscuous mode
br-lan: port 1(eth0.1) entering forwarding state
Compat-wireless backport release: compat-wireless-2011-05-23
Backport based on wireless-testing.git master-2011-05-27
cfg80211: Calling CRDA to update world regulatory domain
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
Registered led device: rt2800pci-phy0::radio
Registered led device: rt2800pci-phy0::assoc
Registered led device: rt2800pci-phy0::quality
usbcore: registered new interface driver rt2800usb
cfg80211: World regulatory domain updated:
cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
loop: module loaded
PPP generic driver version 2.4.2
ip_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 24
ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
rt3883-ehci rt3883-ehci: Ralink RT3883 built-in EHCI controller
rt3883-ehci rt3883-ehci: new USB bus registered, assigned bus number 1
rt3883-ehci rt3883-ehci: irq 26, io mem 0x101c0000
rt3883-ehci rt3883-ehci: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
nf_conntrack version 0.5.0 (1991 buckets, 7964 max)
usb 1-2: new high speed USB device using rt3883-ehci and address 3
xt_time: kernel timezone is -0000
ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
rt3883-ohci rt3883-ohci: Ralink RT3883 built-in OHCI controller
rt3883-ohci rt3883-ohci: new USB bus registered, assigned bus number 2
rt3883-ohci rt3883-ohci: irq 26, io mem 0x101c1000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
Initializing USB Mass Storage driver…
usb 2-1: new full speed USB device using rt3883-ohci and address 2
scsi0 : usb-storage 1-2:1.0
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
usbcore: registered new interface driver belkin
belkin_sa: v1.3:USB Belkin Serial converter driver
USB Serial support registered for cp210x
usbcore: registered new interface driver cp210x
cp210x: v0.09:Silicon Labs CP210x RS232 serial adaptor driver
USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
USB Serial support registered for Keyspan - (without firmware)
USB Serial support registered for Keyspan 1 port adapter
USB Serial support registered for Keyspan 2 port adapter
USB Serial support registered for Keyspan 4 port adapter
usbcore: registered new interface driver keyspan
keyspan: v1.1.5:Keyspan USB to Serial Converter Driver
USB Serial support registered for MCT U232
usbcore: registered new interface driver mct_u232
mct_u232: z2.1:Magic Control Technology USB-RS232 converter driver
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
scsi 0:0:0:0: Direct-Access Generic Flash Disk 1.68 PQ: 0 ANSI: 2
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] 4096000 512-byte logical blocks: (2.09 GB/1.95 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda1 sda2
sd 0:0:0:0: [sda] Attached SCSI removable disk
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
EXT3-fs: barriers not enabled
JBD: no valid journal superblock found
EXT3-fs (sda1): error loading journal
device wlan0 entered promiscuous mode
br-lan: port 2(wlan0) entering forwarding state
device wlan0 left promiscuous mode
br-lan: port 2(wlan0) entering disabled state
device eth0.1 left promiscuous mode
br-lan: port 1(eth0.1) entering disabled state
device eth0 left promiscuous mode
ramips-wdt: timeout value 60 must be 0 < timeout < 25
Any ideas? Also I can not seam to get any other USB items to work like arudino or 10x controllers
