I am a Linux rookie…so pls. forgive me if I ask something stupid…
Vera3, 1.5.322
I googled a lot but I didn´t find a solution
I have a 2GB USB stick connected on the lower usb port of vera3.
I enabled to store logs on USB device
x Store logs on USB device*[i]
WARNING: please do not remove USB stick while Vera is running.
USB status
Enabled
Mounted: read-write
Usage: 5%
Errors log:
2012-03-13_13:42:46 CHECKDISK: Starting to check device: /dev/sda1 with: /usr/sbin/e2fsck
2012-03-13_13:42:48 (/dev/sda1) : Successfully checked[/i]
as far as I understand and see the data logging should work an /dev/sda1
I have a problem to setup dataMine
http://code.mios.com/trac/mios_datamine
I have a problem with the following comand: mount /dev/scsi/host0/bus0/target0/lun0/part1 /dataMine
I get the following error message:
mount: mounting /dev/scsi/host0/bus0/target0/lun0/part1 on /dataMine failed: No such file or directory
The dataMine directory is there - for sure!
My understanding is, that Vera is making 2 partitions when I enable logging to the USB stick → it would not be a good idea to mount dataMine to sda1 because there the logging should take place.
I think that there is also sda2:[i]
fdisk -l
Disk /dev/mtdblock0: 0 MB, 524288 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn’t contain a valid partition table
Disk /dev/sda: 2021 MB, 2021654528 bytes
63 heads, 62 sectors/track, 1010 cylinders
Units = cylinders of 3906 * 512 = 1999872 bytes
Device Boot Start End Blocks Id System
/dev/sda1 * 1 269 525356+ 83 Linux
/dev/sda2 270 1010 1447173 83 Linux[/i]
I tried to mount partition 2:
mount /dev/sda2 /dataMine
mount: mounting /dev/sda2 on /dataMine failed: Invalid argument
What must I do to mount everything right for dataMine?
!!THANK YOU!!!
