Has anybody else been receiving the following error? It used to happen sporadically and could be fixed by restarting ConciergeServer.
It’s now happening very frequently and it’s making my Google Home integration unusable.
I am running the latest ConciergeServer (2.031) on a Synology NAS with Java 1.8.0_151.
Feb 3, 2019 11:13:11 AM I:VeraService:Start
Feb 3, 2019 11:13:11 AM I:VeraConnect.VeraGateway:URLConnection:https://sta1.mios.com/locator_json.php?username=<USER_NAME_HERE>
Feb 3, 2019 11:13:13 AM E:VeraConnect.VeraGateway:URLConnection:BadResponse:429
Feb 3, 2019 11:13:13 AM I:VeraConnect.VeraGateway:URLConnection:https://sta2.mios.com/locator_json.php?username=<USER_NAME_HERE>
Exception:javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.Alerts.getSSLException(Alerts.java:154)
at sun.security.ssl.SSLSocketImpl.recvAlert(SSLSocketImpl.java:2033)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1135)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1564)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492)
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:347)
at com.rtsservices.veraconnect.access.VeraGateway.URLConnection(VeraGateway.java:115)
at com.rtsservices.veraconnect.access.VeraGateway.URLRequest(VeraGateway.java:71)
at com.rtsservices.veraconnect.access.UI5Gateway.GetVeraIDs(UI5Gateway.java:29)
at com.rtsservices.conciergeserver.VeraService.Start(VeraService.java:74)
at com.rtsservices.conciergeserver.Configuration.ValidCmd(Configuration.java:104)
at com.rtsservices.conciergeserver.CSWebContainer.handle(CSWebContainer.java:40)
at org.simpleframework.http.socket.service.RouterContainer.handle(RouterContainer.java:106)
at org.simpleframework.http.core.RequestDispatcher.dispatch(RequestDispatcher.java:121)
at org.simpleframework.http.core.RequestDispatcher.run(RequestDispatcher.java:103)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Feb 3, 2019 11:13:13 AM I:VeraConnect.VeraGateway:URLRequest: No Response!
