I would ask if it possible to upgrade to UI5 with my Vera 2, do a backup and restore the backup on a Vera 3.
It is possible?
Is it possible to work with the two vera in parallel with the same device?
Thank you
Matteo
It is possible?
Thank you
Matteo
You can use the backup of vera 2 that is on UI4 onto Vera 3. But you’ll have to redo your settings as not everything will transfer over. Your zwave devices will be intact. I would not run them in parallel as they will both communicate to the device for scenes etc. I would turn the one you are not using off.
You can brigde multi units together and in doing so, expose an single device across multiple units. What are you trying to achieve as an outcome?
