After updating to the new fireware 1.7.1320 on a veraEdge I lost the connetion to a fibaro FGS-222 switch
has anybody get the same error?
but I see I now can connect to the internet Through a wi-fi access point and that good
This option has missing in veraEdge it was in the old vera 3, I will test it and report back if it Works or not
The wifi er working on the vera Edge, the only problem I can see is that it is not connec to the wifi access Point with the most signal
if you have a lot of access point
may be a log to a access point mac adress will be nice if this is possibel
Did you get it working? I can’t get either of my two FGS222 to pair with the current firmware.
Edited to add: I was able to get them paired with the current firmware - I had best success when I just connected the L, N, I and first output (4 wires) and used the B button 3 times. After I got it joined I went back and finished the wiring.
