Update Neighbor Nodes - does it work?
On UI7, I always get the message: “Received empty response” (whatever that means).
It seems to me that this function is more important now than ever, given that there’s no way to force a network heal.
So, anyone know if it actually does anything or is it broken?
Do your scenes and devices work correctly?
If so, then it’s not a problem. Don’t be concerned with spurious messages. If something doesn’t work, then the messages might be meaningful.
If there is a problem that a network heal can resolve, it should be gone by the next day. But, if not, then you’d be best served by calling support.
Sorry, but needing to wait till the next day for a heal to happen to resolve a routing issue is a major step backwards. I don’t have an issue. I wanted to know if update neighbors worked or not.
