I have a remotely located Vera2 and, thankfully, a helpful neighbor. For the past 3 days, my Vera2 has been unresponsive when I’ve tried to login to it remotely via UI4. After the first day of not being able to login, I had a neighbor power down / powere up the unit which did not fix the problem. I then had them try powering off my modem, wireless router and Vera2 and then power up (thinking an entire system reboot might fix the problem). That did not work and I still cannot login to it remotely - the login process just hangs and I can see the ‘server busy’ message cycling in the background.
When the ‘data not loading’ window box appears with the links to: ‘Setup your network’, ‘Upgrade your firmware’, ‘Activate remote assistance’ and ‘Request tech support’, I’ve tried selecting activate remote assistance and request tech support, only be be re-directed to a page that comes up blank.
Any suggestions on what to do next or how to go about logging a support request that will be replied to? I logged a support request to micasaverde thru their website link earlier this week when the unit was working, and have yet to recieve a response (had an issue with the timer not turning lights off when set for an hour or more).
Greatly appreciate any advice or help.
