Unlock a door using Luup code
I am trying to unlock a door using Luup code in a scene and need some help.
I have tried this code and in the GUI it turns on the Unlocked button but the door remains locked.
luup.variable_set(“urn:micasaverde-com:serviceId:DoorLock1”,“Status”,“0”,145)
Can anyone help me with the correct code?
Probably you want luup.call_action().
Something like:
luup.call_action("urn:micasaverde-com:serviceId:DoorLock1", "SetTarget", { "newTargetValue" = "0" }, 145)
The internal implementation for the SetTarget function will attempt to unlock the door, and if it’s successful it will set Status to 0, updating the GUI.
Edit: This is WRONG. See mcvflorin’s post below.
Thanks futzle for you help but that still doesn’t work. I don’t get any error when saving the scene but activating it does nothing. The door lock icon does not turn green indicating a received command.
You have to remove the “” surrounding the newTargetValue.
luup.call_action("urn:micasaverde-com:serviceId:DoorLock1", "SetTarget", { newTargetValue = "0" }, 145)
Thanks mcvflorin. (In my defence, I was messing about with JavaScript this morning. Lua syntax just doesn’t stick with me. Square brackets and quotes, or neither. One day I’ll remember.)
Don’t worry futzle, I learned this the hard way. :slight_smile:
Thanks mcvflorin, that works. Now I can finally simplify the need to send a 10 second delayed unlock command to my Schlage locks after I enter a valid door code and my virtual “WeAreHome” flag is set. I don’t know of any other way of turning off the “after 5 seconds re-lock the door” factory setting.
function unlockdelay()
luup.call_action(“urn:micasaverde-com:serviceId:DoorLock1”, “SetTarget”, { newTargetValue = “0” }, 145)
luup.call_timer(“unlockdelay”, 1, 10, “”,“”)
luup.call_delay(“unlockdelay”, 10)
return false
Edit: Added luup.call_delay function
I would use luup.call_delay instead just because it’s simpler.
