My first generation Vera bit the dust. I just received a new Vera Plus.
I need to “Uninclude” my old devices, using the new Vera Plus, as the old Vera is dead.
How?
Thanks.
How?
Thanks.
I think the easiest way would be to install the ALTUI app. Under the controllers submenu, it has a button for exclusion. The process in UI7 is convoluted and assumes you are trying to exclude a device that has been included on your system.
Using the UI7 GUI follow the procedure to Include your switch.
While your Vera is in Include mode and is failing to find a device, don’t wait for it to time out, click Next. Your Vera will then switch to Exclude mode and you can Exclude your switch.
You can do it by pressing Vera Plus buttons in certain sequence
Full recipe (including how to go to the inclusion mode) can be found here:
http://forum.micasaverde.com/index.php/topic,36436.msg336288.html#msg336288
Thanks. Now, my other problem is, I have switches of different makes, and they’ve been in for a while, and I don’t have the owner manuals any longer. What’s the most common include/exclude procedure? I"m assuming holding it on for x number of seconds?
Typically it is press and hold or press number of times.
You can find most manuals on the internet, although not necessarily on producer’s webpage.
I got in the habit of downloading manuals years ago to save file space and finding the manuals faster.
Pressing Select button, no lights ever illuminated. I am able to connect to Vera via web browser, though. Bad controller?
