I’m able to successful log into the VeraPlus with Putty, but when trying to do the same with FileZilla or WinSCP, I get this error:
unexpected end-of-file from SFTP server
Any idea how to fix this?
same problem
i need to transfer files from my desktop to the vera unit, i’m using winspc
any idea?
This is an old coversation, but someone should explain the problem. This situation is fixed if you add “-scp” in the command. Example: pscp -scp -P 22 utility.lua root@192.168.0.180:/usr/lib/lua
