Hello all, I was wondering if someone could read the below log portion and tell me if it saying there is a prob with the network.
many thanks for any help!
02 09/24/12 15:00:26.373 e[33;1mZW_Send_Data node 8 USING ROUTE 255.24.186.127e[0m <0x2b65f680>
04 09/24/12 15:00:26.512 <0x2b25f680>
02 09/24/12 15:00:52.103 e[33;1mZW_Send_Data node 9 NO ROUTE (nil)e[0m <0x2b65f680>
02 09/24/12 15:00:54.243 e[33;1mZW_Send_Data node 9 NO ROUTE (nil)e[0m <0x2b65f680>
02 09/24/12 15:00:56.373 e[33;1mZW_Send_Data node 9 USING ROUTE 255.136.0.0e[0m <0x2b65f680>
04 09/24/12 15:00:56.502 <0x2b25f680>
02 09/24/12 15:01:22.103 e[33;1mZW_Send_Data node 10 NO ROUTE (nil)e[0m <0x2b65f680>
02 09/24/12 15:01:24.243 e[33;1mZW_Send_Data node 10 NO ROUTE (nil)e[0m <0x2b65f680>
02 09/24/12 15:01:26.373 e[33;1mZW_Send_Data node 10 USING ROUTE 8.0.0.0e[0m <0x2b65f680>
04 09/24/12 15:01:26.532 <0x2b25f680>
02 09/24/12 15:01:52.103 e[33;1mZW_Send_Data node 4 NO ROUTE (nil)e[0m <0x2b65f680>
02 09/24/12 15:01:54.243 e[33;1mZW_Send_Data node 4 NO ROUTE (nil)e[0m <0x2b65f680>
02 09/24/12 15:01:56.373 e[33;1mZW_Send_Data node 4 USING ROUTE 8.0.0.0e[0m <0x2b65f680>
04 09/24/12 15:01:56.502 <0x2b25f680>
02 09/24/12 15:02:22.102 e[33;1mZW_Send_Data node 5 USING ROUTE 255.152.149.126e[0m <0x2b65f680>
04 09/24/12 15:02:22.242 <0x2b25f680>
01 09/24/12 15:02:37.472 e[31;1mJobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 2388e[0m <0x2b45f680>
01 09/24/12 15:02:37.780 e[31;1mJobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 1408e[0m <0x2b45f680>
01 09/24/12 15:02:38.397 e[31;1mJobHandler_LuaUPnP::GetPluginVersionOnline failed to convert 2468e[0m <0x2b45f680>
02 09/24/12 15:02:52.102 e[33;1mZW_Send_Data node 6 USING ROUTE 255.118.105.99e[0m <0x2b65f680>
04 09/24/12 15:02:52.232 <0x2b25f680>
02 09/24/12 15:03:22.103 e[33;1mZW_Send_Data node 8 NO ROUTE (nil)e[0m <0x2b65f680>
02 09/24/12 15:03:24.233 e[33;1mZW_Send_Data node 8 NO ROUTE (nil)e[0m <0x2b65f680>
02 09/24/12 15:03:26.402 e[33;1mZW_Send_Data node 8 USING ROUTE 255.24.186.127e[0m <0x2b65f680>
04 09/24/12 15:03:26.542 <0x2b25f680>
02 09/24/12 15:03:52.103 e[33;1mZW_Send_Data node 9 NO ROUTE (nil)e[0m <0x2b65f680>
02 09/24/12 15:03:54.233 e[33;1mZW_Send_Data node 9 NO ROUTE (nil)e[0m <0x2b65f680>
02 09/24/12 15:03:56.362 e[33;1mZW_Send_Data node 9 USING ROUTE 255.136.0.0e[0m <0x2b65f680>
04 09/24/12 15:03:56.502 <0x2b25f680>
03 09/24/12 15:04:18.597 JobHandler_LuaUPnP::Reload: reload Critical 1 m_bCriticalOnly 0 dirty data 1 <0x2dc5f680>
06 09/24/12 15:04:18.665 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: e[35;1mNetStatusIDe[0m was: 1 now: 2 #hooks: 0 upnp: 0 v:0x8ba658/NONE duplicate:0 <0x2dc5f680>
06 09/24/12 15:04:18.665 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: e[35;1mNetStatusTexte[0m was: OK now: Resetting ZWave Network #hooks: 0 upnp: 0 v:0x8cf568/NONE duplicate:0 <0x2dc5f680>
01 09/24/12 15:04:18.808 e[31;1mMongoose XXX-mg_stop1 0x7ee458 1 2e[0m <0x2ab2b000>
01 09/24/12 15:04:20.808 e[31;1mMongoose XXX-mg_stop2 0x7ee458 2 2e[0m <0x2ab2b000>
01 09/24/12 15:04:20.809 e[31;1mMongoose XXX-mg_stop3 0x7ee458 2 2e[0m <0x2ab2b000>
01 09/24/12 15:04:20.809 e[31;1mMongoose XXX-mg_stop4 0x7ee458 11167064 2e[0m <0x2ab2b000>
